LTC2983 temperature board
Hello, I am testing the LTC2983 connected to a Teensy 3.6 and the values of the temperature (RTD, PT100, 2wire) are always floating and not stable.
I need your help to define the problem. Thank you so much.
done
[edited by: WBer97 at 1:43 PM (GMT -4) on 7 Oct 2021]
Top Replies
  • Hi  ,
    Have you tried using the LTC2983 Demo software? The demo software enables you to check if your connections are valid, and it also creates a c file that you can use as a guide when programming…
