I am attempting test on multiple 5B47 modules and they all mimic an output voltage in the 6-6.5v range. No temperture input and also same results if I use a temperture output calibrator.
I am using a regulated 5V supply. I am grounding enable and I/O common to same common ground.
Is there something amiss in testing for 0-5 volt output ?
thank you
