ADT7470 GPIO Status - part 2
I have the same problem with ADT7470 not being able to set GPIO output state, as it was already discussed at this question page - https://ez.analog.com/temperature_sensors/f/q-a/77459/adt7470-gpio-status/276442.
I've tried setting register 0x81 and I also found in latest datasheet revision in table 49 (0x80 register) for GPIO direction for each port saying "Data for GPIO 3 is set by the LSB of the PWM3 min duty cycle register" so I tried changing PWM min duty cycle register as well, but both of these things didn't work.
But I can confirm that polarity workaround works.
Is this problem solved in some of next revisions of the chip since fore mentioned discussion is made?
Jovan
