AC switch w 3Vdc control signal, are there such componant or circuit?
I'm looking analog ac switch that controled only w 3Vdc signal
- the ac switch can pass (the control signal is around 500mVdc) around 5W power (20Vac pp) w minimal Rdson (up to 200mOhm)@ 500KHz
- the ac switch can block (using the 3Vdc control signal) 25Vac pp (50mA) @ around 10MHz (as if it was 10Kohm resistor)
Does such element or configurtation exsits and if not what can i do?
I though about:
- antiseriel Fets but i'm not sure the cap @ 10Mhz won't short the Fet and not do the blocking
- relay i'm not sure its not expansive and if it is possible to find some low profile relay
- Opto Mos , i'm not sure it can pass power
- maybe some linear element that i could have samples for my project & test it
- trieac i'm same as relay
attached conceptual circuit the 50Ohm has no meaning just the switch concept
Pls i would be glad if someone could advice me
BR
Arye
Parents Reply Children
No Data
