ADG707 unused inputs
What is the correct thing to do with unused differential inputs on the ADG707 mux ?
thanks,
  • kschoen,
      I would tie the inputs to a voltage source that is guaranteed to always be between the rails or to
    one of the rails.  To be on the safe side, put a resistor in series with the line to Vdd or Vss.
    The abs max section on page 5 says to limit the current through an input pin to < 30 mA,
    I'd keep it a little bit less, say 10 mA.  So 5V/10 mA = 500 ohm.  So you could use 1k to
    ground and go to all the unused inputs.
    Harry
    on Aug 2, 2018 4:36 PM
    Thank you,
    EZ Admin
