I want the schematic and layout informations of ADN4600-EVALZ
because my customer may use ADN4600 by DVI and SDI crosspoint switch.
Could anyone give me the PCB schematic/layout information?
Thanks.
ADN4600
Production
The ADN4600 is an asynchronous, nonblocking crosspoint switch with eight differential PECL-/CML-compatible inputs with programmable equalization and eight...
Datasheet
ADN4600 on Analog.com
Thanks.
I have attached files for the schematic and the user's guide. I have requested the board layer files from our CAD group and will attach them when I receive them.
Note that some of the documents are titled ADN8102. This is because the same board is used for both the ADN4600 and ADN8102.
Thank you for uploading the files.
If you got the board layer files please upload here.
Thanks.
The attached zip files contains the ADN4600 Eval Board layers as pdf files.
