Hello everyone,
is there any information on how to design the schematic for the ADG732?
If not, is there anything important to consider?
Thanks in advance!
Chris
| SLA Status | Assignee | Support Status |
| SLA Closed. | Open | |
ADG732
Production
The ADG726/ADG732 are monolithic, complementary metal oxide semiconductor (CMOS) 32-channel and dual 16-channel analog multiplexers. The ADG732 switches...
Datasheet
ADG732 on Analog.com
Hello everyone,
Thanks in advance!
Chris
Hello CChris,
What is the application of your circuit? Is there anything particular you need to achieve?
Other than using decoupling capacitors for the power supply, and if you are using the LFCSP package, tying the exposed pad to Vss (lowest supply voltage), there is nothing specific to the ADG732.
Sean
Hello Sean,
I just want to multiplex some analog signals, because I only have a few ad-ports free on my µC.
I think, this is nothing extraordinary. So I only will use the decoupling capacitors. (We need the TQFP Package)
Thanks for your help!
Von: seanbrown analog@sgaur.hosted.jivesoftware.com
Gesendet: Freitag, 11. Mai 2012 16:11
An: Christopher Baumann
Betreff: New message: "ADG732 schematic"
EngineerZone<http://ez.analog.com/index.jspa>
Re: ADG732 schematic
created by seanbrown<http://ez.analog.com/people/seanbrown> in Switches/Multiplexers - View the full discussion<http://ez.analog.com/message/50128#50128>
