I am having a problem with an analog switch that we get from MAXIM. I would like to replace it with an ADG4612 or ADG1611 it will
run from +6V to GND the signal inputs are less than 5V in a DC circuit. I have attached the circuit for reference. Any suggestions that
you might have would be appreciated. The circuit selects between 1 or 10 uA of output current by bypassing the resistor with an analog
switch. I was leaning toward the ADG4612 because the data sheet states that it has no power sequencing requirements.
thanks for your help.
Kirk
