Hey to you all,
I have a stupid problem, like problems mostly are.
I use a AD5274, it is a I2C controllable potentiometer, you can set the potentiometer value by sending a 8 bit value towards its RDAC register, and when it is fine for you, you can give a command to store this RDAC value into memory. After a power cycle the last programmed RDAC value will be used to configure the wiper position.
All works fine until now. I can configure and even program I get ACK from the device but after doing a power cycle to last programmed value isn't coming back. I checked everything but can not find a reason why it wont do what it should be. Does anyone have experience whit this device?
Thanks in advance.
Peter
