The truth table in the data sheet shows an Enable pin that turns off all switches. Yet there doesn't seem to be such a pin on the device. I would like to be able to turn off all switches.
| SLA Status | Assignee | Support Status |
| SLA Closed. | Open | |
ADG725
Production
The ADG731/ADG725 are monolithic, CMOS, 32-channel/dual 16-channel analog multiplexers with a serially controlled 3-wire interface. The ADG731 switches...
Datasheet
ADG725 on Analog.com
Hello Steve,
The Truth table indicates the Mnemonics given to the data-bits sent using the SPI interface. In the case of the ADG725, /EN is is the MSB, as indicated in Figure 2 on Page 5 of the datasheet.
There is no physical enable pin.
Sean
