ADG725/ADG731 programming
I'm using several ADG731 and 725 in a design (at least 5 total). Right now the design is not finalized but I was wondering about programming the chip since table I and II are actually contradictory: the first line claims that the switch state will not change whenever CSb/CSAb/CSBb are high, but the
second one that all switches will be off whenever ENb is high.
This must be some documentation error!
Right now  my question is, which of CSb and ENb has priority over the other?
  • Hello GabrielIP,
    The /EN bit is used to control the physical switches. When /EN is high, all switches are off, regardless of the settings in the registers.
    /CSA and /CSB are used to control the registers. When /CSA or /CSB are high, you can write new A3:A0 values, but they will not change.
    Sean
  •      Hello Sean,
    Thanks for replying but It does not answer the question.
    Please look at table I of the documentation (ADG725 truth table): the first line claims that nothing changes if /CSA and /CSB are high regardless of /EN, the second one that all the switches are off if /EN is high regardless of /CSA and /CSB. This is contradictory: it must be either one or the other.
    The question is: what happens if all 3 (/EN, /CSA and /CSB) are high (are all switches disabled or is the switch state unaffected)?
    By analogy with the parallel interface of ADG726/ADG732, I suspect that the /EN bit is only taken into account whenever /CSA or /CSB (the corresponding half) is low and that the second line of tables I and II should have 0 in the /CS* columns.
  • Hello GabrielIP,
    If all 3 (/EN, /CSA and /CSB) are high, all switches are turned off and the switch registers are not changed.
    Example:
    Input1  = [ A3| A2 | A1 | A0 | /EN | /CSA | /CSB] = [0|1|0|0|0|0|0] = S5A – DA, S5B – DB
    Output1 = S5A – DA, S5B – DB
    Input2 = [0|0|1|0|1|1|1] = S3A – DA, S3B – DB, and "All switches off" and "Retain Previous Switch condition" for both A and B
    Output2 = None, All switches off
    Input3 = [1|0|0|0|0|1|1] = S9A – DA, S9B – DB, and "Retain Previous Switch condition" for both A and B
    Output3 = S5A – DA, S5B – DB
    Input4 = [1|0|0|0|0|0|1] = S9A – DA, S9B – DB, and "Retain Previous Switch condition" for B
    Output4 = S9A – DA, S5B – DB
    In the above example, all the switches are off when /EN is high. The required state of the switch can only be written to if the /CSA and /CSB bits are low. The switch registers were written to twice with different conditions with Input2 and 3, but they retained their condition from Input1. The B output did not change with any input other than Input1.
    Sean
  • Hi Sean,
    Thanks, this clears up my doubts.
    If I understand correctly, this means that I can't disable the A side while having the B side still on. I don't need this capability for the current project, but I need A side and B side to be independently selectable.
    This seems to be subtly different from the parallel interface equivalent (ADG726) behavior, which I can't use easily (running out of FPGA I/O pins with 5 chips to program).
  • Hello GabrielP
    It is not possible to individually disable the A and B sections. It is possible to individually select switches, though it has to be done with two writes; see the example above, input3 and input4.
    Sean
  • I agree with Gabriel P,
    Documentation should be :
    A3 A2 A1 A0 EN CSA CSB Switch Condition
     X  0   1   1 Retains Previous Switch Condition
     X  1   X   X All Switches OFF
    instead of
     X    1   1 Retains Previous Switch Condition
     X  X  X  1   X   X All Switches OFF
    If EN is '1', it takes priority over CS, so CS features are only available when EN is 0. Which is well explained in Sean example.
    Regards
