Capacitance Cds(on)
we are using two Multiplexer/Switches ADG1404,ADG1436 to change measurement ranges in an application. While measuring low currents we use a high resistance of about 1MOhm to convert the current into a voltage. The problem that occurs is, that the Capacitance Cds(on) together with the resistance leads to a lowpass-filter with a very low corner frequency.
Is there a way to compensate the internal Capacitance of the switch?
Thanks in advance
Kind regards
Ronny
Parents
    on Oct 16, 2014 7:50 AM
    Hi Ronny,
    It sounds like you really need a low capacitance switch.  If you are using 1MOhm do you really need to use low Ron switches like the ADG14xx family?  If not I would suggest you look at the ADG1204 and ADG1236 switches which have much lower capacitance (but higher Ron).  The ADG12xx family are optimized for low capacitance.
    Eric.
Reply
    Hi Ronny,
    Eric.
Children
No Data
