ADG5404 cross talk?
hello,
ive some problem with my designed multiplexer card, i attach the schematic, see adg5404.jpg.
the address is set to 0:
if i switch +24V on out_1 and measure the results on out_mplex_1 and out_mplex_2,
now i get some heavy spark on the out_mplex_2, see osci_1.jpg.
the address is set to 1:
if i switch +24V on out_1 and measure the results on out_mplex_2 and out_mplex_3,
now i get some little spark on the out_mplex_3, see osci_2.jpg.
is this an design error?
why is the spark on out_mplex_2 such high?
some hints for me?
thanks a lot
attachments.zip
  • Hi Nico,
    Initially looking at your plots what comes to mind is switch charge injection effects.  I have attached an FAQ that has some Q&A on glitches caused by charge injection.  An experiment to do would be to increase the shunt capacitance on the output and see if it helps.
    Eric.
    Ask26-SwitchesandMultiplexers.pdf
  • Hi Nico,
    That's great that helped.  I think this would point towards the speed of the logic transition when using the 100k compared to the 10k affecting the charge injection mechanism.  The logic input is into a high impedance buffer with associated capacitance, see the equivalent circuit for the charge injection mechanism. If using pull up/down resistors I would typically use 10kohm resistors on our switch evaluation boards.
    Eric.
  • Hello,
    thanks for the information.
    i change the pulldown from the address line from 100k to 10k and it seems that the issue is gone.
    how could this?
    thx
