ADG1414: Influence of clock signal at Pin 1 to 8 switches at other Pins S and D
ADG1414*  Why the clock signal connected to Pin 1 can be observed at other Pins S and D, the observed amplitude is about 50 mV at each switch (Pins S and D). How to solve the problem? Thank you!
Parents
  • HI,David
        Thanks for your good suggestion! I will design according to it! Thank you very much!
         Best regards
          Jufang
    发自我的 iPhone
    在 2017年8月29日,下午7:10,Davidforde <analog@analog-vm.hosted.jivesoftware.com> 写道:
    Re: ADG1414: Influence of clock signal at Pin 1 to 8 switches at other Pins S and D
    reply from Davidforde in Switches/Multiplexers - View the full discussion
    Hi Jufang,
    When designing your PCB board you should try and avoid running the Clock lines near the switch inputs/outputs. This will avoid any cross coupling. If possible you could also use different layers for the signals. You could also put a grounded shield between the traces if they have to run along side each other.
    for more tips you could also have a look at the following article:
    A Practical Guide to High-Speed Printed-Circuit-Board Layout | Analog Devices
    David
    Reply to this message by replying to this email, or go to the message on EngineerZone
    Start a new discussion in Switches/Multiplexers by email or at EngineerZone
    Following Re: ADG1414: Influence of clock signal at Pin 1 to 8 switches at other Pins S and D in these streams: Inbox
    This email was sent by EngineerZone because you are a registered user.
    You may unsubscribe instantly from EngineerZone, or adjust email frequency in your email preferences
Reply
  • HI,David
         Best regards
          Jufang
    发自我的 iPhone
    Hi Jufang,
    David
Children
No Data
