Hi. I am using ADG619 in my circuit. Before the final implementation I want to simulate the whole circuit using a spice simulator but I'm unable to find the spice model for ADG619. Can anybody send me a ink from where I can download it. Thanks.
Hi Jayesh Pamar,
Unfortunately, the ADG619 has no available spice model.
I could, however, suggest an alternative spice model to use on whom I could see the closest specs to that of the ADG619. Can you share me your application requirement such as:
Best Regards,
May
Hi mayp,
The switch is connected in the feedback path (output to inverting input terminal) of opamp OPA659 in non-inverting amplifier mode. VDD and VSS are +5V and -5V respectively.
Hi JayeshParmar,
There are two options that can be an alternative for your simulation:
Let me know if this helps.
Best Regards,
May
Thanks for your reply.
