Can multiple MAX20327 switches be operated in parallel for increased current capability?
It seems 1 device is rated for passing 1 Amp continuously, can 2 devices in parallel pass 2 Amps continuously?
| SLA Status | Assignee | Support Status |
| SLA Closed. Met after 2 hours |
Awaiting Company Response | |
MAX20327
Recommended for New Designs
The MAX20327 ultra-small, low-on-resistance (RON) double-pole/double-throw (DPDT) analog switches feature Beyond-the-Railsâ„¢ capability that allows signals...
Datasheet
MAX20327 on Analog.com
Hi Oren123 ,
Thank you for reaching out. We have received your inquiry, and a member of our team will assist you shortly.
Gelo
Hi, Oren123 .
Yes, that is correct. By paralleling multiple devices, you can effectively increase the continuous current handling capability.
Christian
Thank you, Cristian. To quantify how 2 parallel switches would share current, it would be helpful to estimate the minimum switch resistance. The datasheet lists maximum and typical values, but no minimum switch resistance. Can ADI provide any guidance for a reasonable limit for minimum switch resistance?
Best Regards, Oren123
Hi, Oren123 .
The product datasheet specifies typical and maximum on-resistance, but a minimum value is not guaranteed, as it varies with process, supply voltage, and temperature.
May I ask how you intend to use the minimum on-resistance? In many cases, the typical value is sufficient for estimation, but we’d be happy to better understand your application and provide more targeted guidance if needed
Christian
Thank you for the helpful guidance, Christian!
