i am using ADG1604 for multiplexing 4 termocouples tyke K. But i am not sure for VSS pin how to connect.
Is this a GND?
Edit Notes
adg1604[edited by: sukhoi at 4:40 AM (GMT -4) on 14 May 2025]
ADG1604
Production
The ADG1604 is a complementary metal-oxide semiconductor
(CMOS) analog multiplexer and switches one of four inputs to
a common output, D, as determined...
Datasheet
ADG1604 on Analog.com
Is this a GND?
Hi, sukhoi .
Could you provide more details about your application, including the input and supply voltage levels? This information will help in recommending the appropriate connection. Typically, for single supply operation, the VSS should be connected to GND.
Christian
