MAX4624
Production
The MAX4624/MAX4625 are low-on-resistance, low-voltage single-pole/double-throw (SPDT) analog switches that operate from a single +1.8V to +5.5V supply...
Datasheet
MAX4624 on Analog.com
Please provide the life cycle status and relevant documents for MAX4624EZT+T.
Hi Utkarsh0070 ,
We've received your inquiry. A team member will respond to you shortly.
Gelo
Hi Geloism16 I have received from reply. EVen I created a case for the same
Hi Geloism16 i haven't received any response , even I registered a case on the portal.
Please reply ASAP as the customer is chasing us.
Hi Utkarsh0070,
The MAX4624EZT+T part is marked as "Last Time Buy" meaning its going end of life. I will see if I can get any more information on this.
Eric.
EricC Can you provide some documents for this.
What is your main concern? Time line to EOL?
Hi Utkash0070,
I found some information.
MAX4624EZT+T Last Order Date : 25-Nov-2025.
Recommended Replacement : ADG719BRT-REEL7.
Eric.
Hi Theresa,
It looks like the datasheet was last updated 24 years ago. Obsolesce is driven by many factors and over that time a lot will have changed. The most update supply information is always in the "Sample & Buy" section on analog.com.
Eric.
Thank you, is there a reason that the recommended replacement is ADG719BRT-REEL7 and not MAX4624EUT+T? Are there plans for MAX4624EUT+T to go obsolete soon?
