ADN4605
Production
The ADN4605 is a 40 × 40 asynchronous, protocol agnostic, digital crosspoint switch, with 40 differential PECL/CML-compatible inputs and 40 differential...
Datasheet
ADN4605 on Analog.com
ADN4604
Production
The ADN4604 is a 16 × 16 asynchronous, protocol agnostic, digital crosspoint switch, with 16 differential PECL-/CML-compatible inputs and 16 differential...
Datasheet
ADN4604 on Analog.com
I've a question about ADN4605 and ADN4604. Can ADN4605 and ADN4604 support SDI Check Field signal (Pathological signal)?
Akira
PoornimaSubramani - Moved from Video to Switches/Multiplexers. Post date updated from Thursday, March 6, 2025 12:47 AM UTC to Thursday, March 6, 2025 6:20 AM UTC to reflect the move.
Hi Akira,
Thank you for your interest in ADN4604 and ADN4605.
Both of these devices support SD-, HD-, and 3G-SDI digital video data rates, so they should also be able to handle the check field signal as part of the SDI protocol's error detection mechanism.
Zaeefa
