would it be possible to input into the multiplexer a negative differential voltage signal (from a thermoucouple measuring low negative voltages : mVs) even though it is powered by a single power supply (Vdd +5V and Vss=GND) ?
I know that in the specs the input analog signal qhould be between 0 and VDD :
but the the maximum rating allows -0.3 Vss:
Would multiplexing thermoucples with negative voltages as low as -10mVs be an issue in Single Suply power ?
Thank you in advance for your help !
