ADG723
Production
The ADG721,
ADG722, and ADG723 are monolithic CMOS SPST switches. These switches are designed on an advanced submicron process that provides low power...
Datasheet
ADG723 on Analog.com
Hi Shubham123 ,
Thank you for bringing this matter to our attention. I am currently conducting a thorough investigation into your concern. Rest assured, I will provide a detailed response as soon as I have gathered all the necessary information.
Christian
Hi Shubham123 ,
Could you please confirm the power-up sequence of the ADG732 when the PCB is powered on? Specifically, does the S to D channel power up before the VDD? If so, this would violate the absolute maximum ratings specified in the product datasheet.
Thank you.
Christian
Dear Sir,
As soon as I powered the PCB, then through resistor string the voltage which generated goes on drain then its connects to source then to the VDD as per my assumption. I will check it on scope and let you know. Currently, what we have done is shorted the wire from capacitor where 5v is coming to its supply pin. And now it is constantly holding supply of 5v even when there is change of state occurs in it.
For your information, the voltage which is coming on supply pin is less than the voltage which is available on drain and source.
Please, let me know if you want more info related to it.
Thanks & Regards,
Shubham
