Abnormal Current
Product Number: ADG411
Recently, I am designing a programmable amplifier based on op amps and analog switches.
The main goals of the system are low power consumption and programmable gain. The analog switch I used is TI's ADG411, and the op amp is analog's THP210.
I use the FPGA to input high and low levels to the analog switch, so I can control different resistors and connect them in parallel to the op amp circuit in order to achieve gain selection.
After welding the board and powering it on for testing, I found that I could achieve the target gain selection and the input signal could be amplified by different factors according to my needs.
However, the overall current of the device is too high.
After testing, I found that the problem lies in ADG411. After switching the resistor, the current of ADG411 is much larger than the typical value.
Although it has not burned out the chip, the design goal of low power consumption cannot be achieved.
I want to know the reason of this Phenomenon. Please help me.
