Break-before-make
Category: Datasheet/Specs
Product Number: ADG5209
Hi, I'm trying to perform a timing analysis on my interface for sensor acquisition. Regarding the ADG5209 t_ON, t_OFF and t_TRANSITION are clear but I can't get if the break-before-make time is already considered inside t_TRANSITION value (expecially in its over temperature maximum value) or if it has to be added, in which case how can I assume a worst case scenario at the higher end of the temperature range?
Thank you!
