| SLA Status | Assignee | Support Status |
| SLA Closed. | Davidforde |
Assigned |
ADG1412
Production
The ADG1411/ADG1412/ADG1413 are monolithic complementary metal-oxide semiconductor (CMOS) devices containing
four independently selectable switches designed...
Datasheet
ADG1412 on Analog.com
This product is considered to be a general industrial product.
Can it be used for aerospace/defense purposes?
If possible, can you provide supporting supporting data?
I am waiting for your advice.
Thank you
Regard,
Josh
Hi doolpung ,
Thank you for your question. As this product is automotive compliant (AEC-Q100), it may not necessarily be compliant with aerospace/defense applications, which adhere to different standards such as the AQEC standard. For instance, the ADG904-EP supports defense and aerospace applications (AQEC standard).
AbdulAziz
Hi Josh,
The ADG1412 is not qualified to be used for both Mil-Aero and Automotive applications.
If the business case is justifiably strong and huge - then it may be possible for a re-qualification to be carried out wherever it is possible to do so.
My colleague initial post was referring to the ADG1411W as the automotive qualified version of the ADG14xx series. Thanks.
edo
Thank you for your support.
Josh
Josh
