Is the Vss pin must be connected to negative supply or left floating?
The user is testing an IC in dual supply mode and asks if the Vss pin should be connected to the negative supply or left floating. The support engineer advises connecting Vss to the negative supply to avoid violating the device's maximum ratings. For ±5V operation, the ADG1208 or ADG1608 models are recommended.
Product Number: ADG5408BRUZ-REEL7, ADG5408
I am trying to test the IC in dual supply mode.But i am confused in whether the Vss pin must be connected to negative supply or left floating as the output results are same in both cases. please guide.
