I am checking the ADG715 datasheet and it talks about ton and toff but not about trise or tfall for the signals that go through the SPSTs. I am planning to connect a signal of 50MHz frequency that will be switching with a trise < 2ns and a tfall < 2ns. Since the octal single-pole, single-throw (SPST) switches are complementary metal-oxide semiconductor (CMOS), is known there would be present a specification of trise/tfall and it is important for my application to understand what is the limit.
If this particular component will not fullfill my needs, could you recommend one that could work with this constraints?
Regards
Jose Enrique
