About ADG1201 LTSPICE model's leakage behavior
The user is experiencing discrepancies between the ADG1201 switch's datasheet leakage specifications and their LTspice simulation results. The support engineer confirmed that the current LTspice model does not include the leakage parameter, leading to incorrect measurements. The user needs accurate leakage data for a peak hold circuit involving a capacitor charged by a sensor, where the capacitor voltage is later converted by an ADC. The support engineer requested additional application details and provided an email for further communication.
Product Number: ADG1201
Software Version: LTSpice XVII(x64)(17.0.35.0)
Hi
We estimate  ADG1201 OFF leakage behavior with LTspice.
Our peak hold circuit have capacitance discharge and ADG1201 is good for discharge SW.
We need to estimate circuit behavior with LTspice.
But we have difference from datasheet spec to LTspice result.
Please advise us anything.
 At first, we confirm ADG1201 characteristics with LTspice.
Below is datasheet condition.
We make below and attached LTspice circuit.
7776.ADG1201.asc
Result is below table
VDD=16.5V VSS=-16.5V VS and VD is in table.
VD=10V VS=-10V
-20nA leakage -I(V4)
VD=10V VS=10V 20nA leakage  -I(V4)
VD=-10V VS=10V 20nA leakage  -I(V4)
VD=-10V VS=-10V -20nA leakage -I(V4)
VD=0V VS=0V less than fA -I(V4)
20nA is over from datasheet spec.
Do we have any wrong ways?
Best regards.
Thank you very much.
Edit Notes
Wrong file attached
[edited by: Jma at 7:09 AM (GMT -4) on 1 Nov 2022]
