Using a dual supply analog switch around 0V
The user inquired about potential issues (glitches, noise, dead-band) when using the ADG1519 SPSD analog switch to handle low noise, low speed signals that swing from +5V to -5V. The final answer confirmed that the performance remains consistent during transitions through 0V, and suggested reviewing the typical performance plots in the datasheet for further guidance.
Product Number: ADG1519
I am considering using the ADG1519 SPSD analog switch to direct a low noise low speed signals that can swing from +5V (the positive supply of the ADG1519) to -5V (the negative supply). My question is: Is there anything bad that happens (glitch, noise, dead-band) as the input signal transition through 0V in either direction?
By the way, congratulation on the low THD+N value for this switch.
Thank you for your help and all the best,
Tony
