ADGS5412 SPI interface diagram possible error
The user queries the correct timing for SDO data output in Address Mode for the ADGS5412, noting a discrepancy between the datasheet text and Figures 39/40. The final answer confirms that SDO data transitions on the falling edge of SCLK, and Figure 2 should be followed for exact timings. The read data starts clocking out on the 9th falling edge, allowing a receiver to latch data on the 9th through 16th rising edges.
The Address Mode section on page 22 of the datasheet for the ADGS5412 states that SDO clocks data out on SCLK falling edges.  However, Figure 39 and Figure 40 show SDO clocking data out on the rising edge.
Also, I find it strange that read data starts clocking out on the 9th falling edge instead of the 8th falling edge.  Starting on the 9th falling edge means that a receiver that clocks in data from SDO on rising edges needs to use the 10th through 17th rising edges.  There isn't an 17th rising edge in Address Mode.  Is the 9th falling edge really when read data start?
I appreciate you help understanding the correct alignment for the SDO output.
