ADG734 and digital input levels with VSS < 0
Hello everyone, I have a question related to ADG734. In a certain application, there is a need to switch between different signal lines that are at a negative voltage around -0.7 to -0.2 V. For that reason, an ADG734 IC used with VDD=+3.3 V and VSS=-1.2 V (and not 0 V). The digital input lines that control the four SPDT switches inside the IC are connected to GPIO pins of another system and swing between +3.3 V and 0 V.
The datasheet of ADG734 states that, with VDD=3 V and VSS=0 V, the input low voltage (VINL) is 0.8 V maximum. Is it right to assume that, for VSS=-1.2 V, VINL=VSS+0.8 V = -0.4 V maximum? If yes, then having the digital input signal that controls the switches at 0 V should NOT be OK and some sort of level shifting, e.g. using a MOSFET switch with VSS=-1.2 V should be used. Is my assumption correct? Please advise.
Parents
    No, your assumption is not correct.
    The digital logic circuitry is powered only by VDD.
    So, the value of VSS should have no impact on the VINL specification.
    David
  • Hi George,
    I would have to agree with David Forde in this case.
    If unsure about the VINL and VINH voltage levels of the ADG734 device, reference the dual supply voltage specification table (+/- 2.5V) as a reference for these voltage values for a dual supply voltage range.
    Would you have a schematic or application specific circuit that you could share to help understand how the negative voltages (-0.7V - -0.2V) are switched between different signal lines in your certain application ?
    Kevin
Reply
  • Hi George,
    Kevin
Children
No Data
