ADG1408: What leads to the high noise contribution with this analog multiplexer?
The user observed a 20x higher noise in a programmable gain stage using the ADG1408 multiplexer compared to a fixed gain stage. The final answer suggests that the simulation model may not be optimized for noise performance, and the reference voltage source used in the simulation does not significantly affect the noise analysis. The user should ensure the switch is closed during the noise simulation to accurately assess performance.
Hi, I am new to this board and I am still trying to find my way around.
Here's my question:
For audio processing purposes, I would like to use a programmable gain stage based on the 8:1 multiplexer ADG1408 and get a qualitative feel for the performance by comparing it against a fixed gain stage. When I look at the time domain, I see pretty good correspondence between the two gain stages. However, when I compare the noise performance, I see a 20x higher noise with the programmable gain stage. Is this really to be expected? Why is it so high? I've added the asc file add the bottom of this post..
6840.mwe2.asc
Edit Notes
Fixed typo
[edited by: Kepa at 8:48 PM (GMT -5) on 13 Dec 2021]
