ADG708 Power sequence
The user asked if it's safe to tie the ENABLE pin of the ADG708 multiplexer to the 3V supply to permanently enable the device. The engineer confirmed that tying the ENABLE pin high will keep the multiplexer enabled, and the circuit should work correctly as long as the 500mVpp sine wave with a 1.13V DC bias is within the device's performance max ratings.
In terms of power sequencing for the ADG708 mux  is it OK to tie the ENABLE pin permanently to a system GND to permanently enable the multiplexer?
This means the enable input will be tied low as power is applied and I do not want to risk damage or stress to the CMOS etc
The multiplexer is used in a single supply 3V system
Many thanks for any info
