HMC1118 RF Switch Spurious levels with Single supply operation
What is typical spurious level when using HMC1118 switch by single positive supply voltage applied to the VDD pin and the negative voltage input pin (VSS) connected to ground?
Please provide test data if available, Also specify spurious frequency ranges.
