Currently our design is considering ADG824 part no to use on QSPI bus.
So, I'm looking for the electrical model. I would like to perform platform timing analysis in Hspice simulation using the model.
Natasya
ADG824
Production
The ADG824 is a low voltage CMOS device containing two independently selectable single-pole, double throw (SPDT) switches. This device offers ultralow...
Datasheet
ADG824 on Analog.com
Natasya
Thanks for getting in touch,
Someone will be in touch shortly to discuss your requirements.
Thanks
David
Hi Natasya,
May I know how will the ADG824 be used un QSPI bus application?
The ADG824 is a parallel interface SPDT switch. Can you share how will this be used in the system?
May
We would like to use this switch for muxing between PCH and EC for Flash sharing.
Natasya
Hi Natasya,
What do you mean by PCH and EC?
What are the parameters you're interested? Ron, leakage, digital input, timing, bandwidth, caps?
May
