ADG1604 - Waveform change when connect input to source terminal
The user encountered significant waveform distortion when connecting a 50 Hz sine wave signal from a current transformer sensor to the S1 terminal of the ADG1604. The issue was resolved by identifying an error in the hardware layout, not a problem with the ADG1604 itself. The user confirmed the original signal waveform was clean when not connected to the ADG1604, and the distortion was consistent across multiple boards.
I'm using ADG1604 for channel selections. The input singal is sinwave, 50 Hz.
When I connect the input to the ADG1604 terminal, the signal waveform is changed alot.
1. My Schematic
2. The orginal input waveform
3. Input signal waveform when connected to the ADG1604
Please help me to findout the reason.
Thank you!
