Hello Everyone,
Are there any plans for a spice simulation model of ADG788 or ADG734?
Thanks.
Hello Everyone,
Thanks.
Thanks for getting in Touch, We are currently working on our LTSpice models. @mayp should be able to provide you with an update.
Thanks
David
Hi, paulplux.
We are currently working on getting more of our Low Voltage Switches in LTspice, especially the ADG7XX series.
At the moment, our lowest voltage switches in LTspice are the ADG6XX and ADG16XX, which operate at +/-5V.
What is your application (Voltage ranges, constraints, main spec)? Maybe we can work around this using a device with similar specs, but different voltage range until we have one of these devices available in LTspice component library.
Yours sincerely,
Igor Ono.
Hi!
I am also interested in the LTSpice model for ADG734.
Regards
Hi paulplusx and Wilhelm Tomasi
Both the ADG734 and ADG788 LTspice models are released on the LTspice Library.
Please complete a sync release on LTspice and you should have access to both models.
Kevin
