I would like to inquire about the power-off protection function of the analog switch being designed.
The problem product was ADG1636, and a warning light(12V power supplied) was turned on while the switch supply voltage 12V was not supplied. (Power-off)
The confirmed symptom is leakage through the switch (ADG1636) signal path, so ADG5436F, a product supporting the power-off protection function was recommended.
However, ADG5436F also has the same symptoms and I ask you to review the power-off protection function.
