I would like to know what is the # between ADG704BRM and ADG704BRMZ? It is only peak temp is different?
Vinh Le
ADG704
Production
The ADG704 is a CMOS analog multiplexer, comprising four single channels. This multiplexer is designed on an advanced submicron process that provides low...
Datasheet
ADG704 on Analog.com
Vinh Le
Hi Vinh Le,
The ADG704BRMZ is a lead free device while the ADG704BRM isn't lead free.
The ADG704BRM is no longer available from ADI.
Stephen
Hello Stephen,
Thanks for the quick response, is this the same for ADG5318ARU and ADG5318ARUZ
Vinh Le
Hi Vinh Le,
I assume you mean the AD5318ARU? The presence of a Z on an ADI part number means the part is RoHS compliant (lead free). We typically do not have non RoHS compliant parts available to order anymore.
Stephen
Thanks Stephen
Hi Stephen,
Wanted to follow up on this to ask if you knew of a good replacement part for the ADG704BRMZ. Is there a good alternative within the same family of multiplexers?
Matt
Hi Matt,
The ADG804 and the ADG1604 are other low voltage, low on resistance 4:1 muxes available in the Analog Device portfolio.
Stephen
