ADG719 using for RF link
When I choose a proper Swith for 10MHz RF signal link swith ,is it right if i ues ADG719 in my application.
the info of ADG719 :
FEATURES
1.8 V to 5.5 V single supply
4 Ω (max) on resistance
0.75 Ω (typ) on resistance flatness
−3 dB bandwidth > 200 MHz
Rail-to-rail operation
6-lead SOT-23 package
Thanks for your answer!
  • Hi Guo,
    My apologies we seemed to have missed your question.
    The ADG719 is designed to pass high frequency signals of up to 200M Hz.
    So in theory it should pass a 10 MHz RF signal.
    Would you be able to give more detail in the type of RF 10 Mhz signal you plan to input into the ADG719 switch ?
    Other factors such as:
    • On Resistance.
    • Capacitance.
    • Propagation Delay.
    Need to be taken into consideration before selecting the correct switch for your application.
    Kevin
