We are planning to use the ADG5208 and would like to tie the outputs together across multiple devices and control the respective enable pins to select one of the input signals to an opamp buffer and ADC. Is that an acceptable use case for the mux? I assume we need to consider the output leakage current as an error source for each shorted MUX. Would you have any further guidance, app notes, etc for connecting multiple MUXes as I've described?
Bill
