Good morning,
I am planning to control the switch AGG1611 with a digital output 5 V from Arduino. I saw that the input is 3V-compatible. Is it possible to use directly the Arduino 5V output or I need to reduce it?
Thank you,
Alessandro
ADG1611
Production
The ADG1611 / ADG1612 / ADG1613 contain four independent single-pole/single-throw (SPST) switches. The ADG1611 and ADG1612 differ only in that the digital...
Datasheet
ADG1611 on Analog.com
Good morning,
Thank you,
Alessandro
It is possible to use 5V to control the ADG1611 providing the Vdd is at least 5 V also. the digital control voltage must not exceed the supply.
David
