Is ADG732 have 32 pins I/O Multiplexer.... if we feed one input(voltage) to the multiplexer i will get exact output (voltage)or not??? rest of the pins what is the status......either high impedance or not....
September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
ADG732
Production
The ADG726/ADG732 are monolithic, complementary metal oxide semiconductor (CMOS) 32-channel and dual 16-channel analog multiplexers. The ADG732 switches...
Datasheet
ADG732 on Analog.com
If you present a signal on a channel, for example S1, and S1 is then selected then that signal will be seen on D. The switch channel has certain characteristics such as Ron, leakage, capacitance, etc, which are described in the datasheet. They will affect the signal so please check the datasheet to see how they may affect your system.
The rest of the channels that are not selected will be high impedance and the off isolation and crosstalk specs describe how much of the signal on an off channel will couple to output and other channels.
Stephen
Thank you Stephen_Nugent....
