Will the ADG1408 function correctly with a single +5 V supply? The datasheet only specifies performance for +-15 V, +12 V, and +-5 V.
The ADG1408 will function with a single +5 V supply. the Functional range of the switch is shown as below in the datasheet.
However this is just functionality and the switch parameters/characteristics may change at this supply voltage. These changes include, but are not limited to: analog signal range, on resistance, leakage, VINL, VINH, and switching times.
Regards
David
Thanks for your reply. Any idea if the analog signal range of the ADG1408 would be affected by running off of a single +5 V supply?
The ADG1408 is a rail to rail switch, so the analog signal range will be with in the supply rails. ( 0 - 5 V in your case )
Hope this helps
David
Hope this helps
David
