ADGM1304 Open Power Handling
The datasheet specifies a maximum power handling of +36 dBm, Based on my evaluation of the switch it appears this number is driven by maximum power in the closed state while conducting.  Is there an alternative, higher specification for power handling in the open state while blocking (not hot switching)? My evaluation seems to indicate the the open power rating which should be limited by cantilever pull-in or arcing may be several dBm higher than the 36 dBm maximum figure.
Top Replies
