Hello ADI,
I have a question about the supply voltage of the ADG5408. I would like to use for VDD a Supply of 5V and for VSS -24V.
Does this connection violate the description below?
Thank you.
Hello ADI,
Thank you.
The ADG5408 requires at least a 9V VDD so that the digital logic section of the switch operates correctly.
The VDD and VSS do not need to match, as long as the difference between VDD and VSS is not greater than 44V.
