ADG5404F switch noise
The user experiences a 5V, 400ns pulse at the D port of the ADG5404F when switching address lines A1 and A0, likely due to charge coupling or charge injection. Adding a 1nF capacitor in parallel with the pull-down resistor eliminates the pulse but reduces the bandwidth. The support engineer suggests considering the ADG5209F, which has lower capacitance and charge injection, and requests scope plots for further analysis.
I'm using the ADG5404F. When I switch the addree A1 and A0, A 5V pulse of approximately 400ns long appears at the D port. This has a serious impact on my system. Is there any solution to remove it? The VDD is 8V. The VSS is -8V. There is 32 adg5404F In my design. The toggle of address line is slow.
    This sounds like it could be caused by charge coupling or charge injection.
    See MT-088 for explanation of these effects.
    Have you looked at the ADG52xxF family. depending on your application you may be able to use an ADG5209F (this is a Dual 4:1 Mux). these devices have lower capacitance and charge injection which could help with your issue. Can I ask what the drain pin is connected to?
    Do you have any scope plots that you could share with me?
    David
  • The drain is connect to a pull-down resistor. When I connect a 1nF capacitor In parallel with the resistor, the pulse disappears. However, The bandwidth of ADG5404F significantly reduces. The figure below shows the measured switch noise.
