Hi
If Exposed pad is connected to GND when using dual power supply.
Could you explain that how it is effecting to circuit functionality / performance ?
Thank you !
ADG5434
Recommended for New Designs
The ADG5433 and ADG5434 are monolithic industrial CMOS
analog switches comprising three independently selectable
single-pole, double-throw (SPDT) switches...
Datasheet
ADG5434 on Analog.com
Hi
Thank you !
The exposed pad is recommended to be soldered to VSS. This is for maximum thermal capability of the device.
Stephen
Stephen
