Possible Bug in Transceiver Toolbox v23.2.2 (ZC706 + ADRV9375), "<error>" is shown in the RF bandwidth attribute
The user encountered issues with the ADRV9375 RF bandwidth not displaying correctly, inability to load profiles, and no data reception when using the Transceiver Toolbox v23.2.2 with MATLAB 2023b and Vivado 2022.2 on the ZC706 platform. The problem was resolved by reverting to Transceiver Toolbox v23.2.1 with MATLAB 2023b and Vivado 2021.2, suggesting a bug in the latest release.
Product Number: ADRV9375
Software Version: Transceiver Toolbox v23.2.2, MATLAB R2023b, Vivado 2022.2
I'm using the Transceiver Toolbox to target my own HDL model on the ZC706 + ADRV9375 platform, and I believe I've encountered a bug in the latest release (v23.2.2).
To verify basic functionality, I built the simplest example model, "testModel_Rx16Tx32_regs.slx", located in the `test` folder. This is the simple delay model provided by the Transceiver Toolbox project. Using MATLAB 2023b and Vivado 2022.2, the model compiles successfully without any errors.
However, when I copy the generated BOOT.bin file to the SD card and boot the platform, the system fails to operate correctly. I used the official device tree and uImage files directly from the 2022_R2 SD card.
The observed behavior is as follows:
- When connected via IIO Oscilloscope, the Rx RF bandwidth of the ADRV9375 is not displayed properly; it shows "<error>" instead of a valid value.
- I cannot load any profile to change the ADRV9375 configuration — it always reports "failed".
- No data is received from the board; IIO Oscilloscope cannot capture any samples once streaming starts.
Screenshots for these behaviors:
I'm confident that the issue originates from the generated FPGA image (BOOT.bin). When I replace it with the official BOOT.bin, the system immediately works as expected.
For further verification, I tested an older Transceiver Toolbox release (v23.2.1) using MATLAB 2023b and Vivado 2021.2. The same model works perfectly in that setup.
Therefore, I strongly suspect this issue is a bug introduced in Transceiver Toolbox v23.2.2.
  • Please provide the full boot log from the board.
    -Travis
  • I've attached the full boot log here.
    U-Boot 2018.01-21439-gd244ce5 (Jul 29 2021 - 16:31:12 +0100) Xilinx Zynq ZC706, Build: jenkins-development-build_uboot-1
    Model: Zynq ZC706 Development Board
    Board: Xilinx Zynq
    Silicon: v3.1
    I2C:   ready
    DRAM:  ECC disabled 1 GiB
    MMC:   sdhci@e0100000: 0 (SD)
    SF: Detected s25fl128s_64k with page size 512 Bytes, erase size 128 KiB, total 32 MiB
    *** Warning - bad CRC, using default environment
    In:    serial@e0001000
    Out:   serial@e0001000
    Err:   serial@e0001000
    Net:   ZYNQ GEM: e000b000, phyaddr 7, interface rgmii-id
    eth0: ethernet@e000b000
    reading uEnv.txt
    407 bytes read in 18 ms (21.5 KiB/s)
    Importing environment from SD ...
    Hit any key to stop autoboot:  2  1  0
    Device: sdhci@e0100000
    Manufacturer ID: 3
    OEM: 5344
    Tran Speed: 50000000
    Rd Block Len: 512
    SD version 3.0
    High Capacity: Yes
    Capacity: 29.7 GiB
    Bus Width: 4-bit
    Erase Group Size: 512 Bytes
    reading uEnv.txt
    Loaded environment from uEnv.txt
    Running uenvcmd ...
    Copying Linux from SD to RAM...
    reading uImage
    8047680 bytes read in 462 ms (16.6 MiB/s)
    reading devicetree.dtb
    32604 bytes read in 25 ms (1.2 MiB/s)
    ** Unable to read file uramdisk.image.gz **
    ## Booting kernel from Legacy Image at 03000000 ...
       Image Name:   Linux-5.15.36-182052-g805c422ae9
       Image Type:   ARM Linux Kernel Image (uncompressed)
       Data Size:    8047616 Bytes = 7.7 MiB
       Load Address: 00008000
       Entry Point:  00008000
       Verifying Checksum ... OK
    ## Flattened Device Tree blob at 02a00000
       Booting using the fdt blob at 0x2a00000
       Loading Kernel Image ... OK
       Loading Device Tree to 1fff5000, end 1fffff5b ... OK
    Starting kernel ...
    Booting Linux on physical CPU 0x0
    Linux version 5.15.36-182052-g805c422ae939 (jenkins@romlxbuild1) (arm-xilinx-linux-gnueabi-gcc.real (GCC) 11.2.0, GNU ld (GNU Binutils) 2.37.20210721) #1545 SMP PREEMPT Tue Jun 18 10:34:01 EEST 2024
    CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
    CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    OF: fdt: Machine model: Xilinx Zynq ZC706
    OF: fdt: earlycon: stdout-path /amba@0/uart@E0001000 not found
    Memory policy: Data cache writealloc
    cma: Reserved 128 MiB at 0x38000000
    Zone ranges:
      Normal   [mem 0x0000000000000000-0x000000002fffffff]
      HighMem  [mem 0x0000000030000000-0x000000003fffffff]
    Movable zone start for each node
    Early memory node ranges
      node   0: [mem 0x0000000000000000-0x000000003fffffff]
    Initmem setup node 0 [mem 0x0000000000000000-0x000000003fffffff]
    percpu: Embedded 11 pages/cpu s14156 r8192 d22708 u45056
    Built 1 zonelists, mobility grouping on.  Total pages: 260608
    Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlycon rootfstype=ext4 rootwait clk_ignore_unused cpuidle.off=1
    Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    mem auto-init: stack:off, heap alloc:off, heap free:off
    Memory: 883984K/1048576K available (12288K kernel code, 804K rwdata, 8036K rodata, 1024K init, 476K bss, 33520K reserved, 131072K cma-reserved, 131072K highmem)
    rcu: Preemptible hierarchical RCU implementation.
    rcu: 	RCU event tracing is enabled.
    rcu: 	RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
    	Trampoline variant of Tasks RCU enabled.
    rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    efuse mapped to (ptrval)
    slcr mapped to (ptrval)
    L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
    L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
    L2C-310 erratum 769419 enabled
    L2C-310 enabling early BRESP for Cortex-A9
    L2C-310 full line of zeros enabled for Cortex-A9
    L2C-310 ID prefetch enabled, offset 1 lines
    L2C-310 dynamic clock gating enabled, standby mode enabled
    L2C-310 cache controller enabled, 8 ways, 512 kB
    L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
    random: get_random_bytes called from start_kernel+0x480/0x638 with crng_init=0
    zynq_clock_init: clkc starts at (ptrval)
    Zynq clock init
    sched_clock: 64 bits at 166MHz, resolution 6ns, wraps every 4398046511103ns
    clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x26703d7dd8, max_idle_ns: 440795208065 ns
    Switching to timer-based delay loop, resolution 6ns
    clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
    timer #0 at (ptrval), irq=25
    Console: colour dummy device 80x30
    Calibrating delay loop (skipped), value calculated using timer frequency.. 333.33 BogoMIPS (lpj=1666666)
    pid_max: default: 32768 minimum: 301
    Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    CPU: Testing write buffer coherency: ok
    CPU0: Spectre v2: using BPIALL workaround
    CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    Setting up static identity map for 0x100000 - 0x100060
    rcu: Hierarchical SRCU implementation.
    smp: Bringing up secondary CPUs ...
    CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    CPU1: Spectre v2: using BPIALL workaround
    smp: Brought up 1 node, 2 CPUs
    SMP: Total of 2 processors activated (666.66 BogoMIPS).
    CPU: All CPU(s) started in SVC mode.
    devtmpfs: initialized
    VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
    clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    pinctrl core: initialized pinctrl subsystem
    NET: Registered PF_NETLINK/PF_ROUTE protocol family
    DMA: preallocated 256 KiB pool for atomic coherent allocations
    thermal_sys: Registered thermal governor 'step_wise'
    amba f8801000.etb: Fixing up cyclic dependency with replicator
    amba f8803000.tpiu: Fixing up cyclic dependency with replicator
    amba f8804000.funnel: Fixing up cyclic dependency with replicator
    amba f889c000.ptm: Fixing up cyclic dependency with f8804000.funnel
    amba f889d000.ptm: Fixing up cyclic dependency with f8804000.funnel
    hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
    hw-breakpoint: maximum watchpoint size is 4 bytes.
    e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 32, base_baud = 3125000) is a xuartps
    printk: console [ttyPS0] enabled
    SCSI subsystem initialized
    usbcore: registered new interface driver usbfs
    usbcore: registered new interface driver hub
    usbcore: registered new device driver usb
    mc: Linux media interface: v0.10
    videodev: Linux video capture interface: v2.00
    pps_core: LinuxPPS API ver. 1 registered
    pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    PTP clock support registered
    jesd204: created con: id=0, topo=0, link=0, /axi/spi@e0006000/ad9528-1@0 <-> /fpga-axi@0/axi-adxcvr-tx@44a80000
    jesd204: created con: id=1, topo=0, link=2, /axi/spi@e0006000/ad9528-1@0 <-> /fpga-axi@0/axi-adxcvr-rx-os@44a50000
    jesd204: created con: id=2, topo=0, link=1, /axi/spi@e0006000/ad9528-1@0 <-> /fpga-axi@0/axi-adxcvr-rx@44a60000
    jesd204: created con: id=3, topo=0, link=2, /fpga-axi@0/axi-adxcvr-rx-os@44a50000 <-> /fpga-axi@0/axi-jesd204-rx@44ab0000
    jesd204: created con: id=4, topo=0, link=0, /fpga-axi@0/axi-adxcvr-tx@44a80000 <-> /fpga-axi@0/axi-jesd204-tx@44a90000
    jesd204: created con: id=5, topo=0, link=1, /fpga-axi@0/axi-adxcvr-rx@44a60000 <-> /fpga-axi@0/axi-jesd204-rx@44aa0000
    jesd204: created con: id=6, topo=0, link=0, /fpga-axi@0/axi-jesd204-tx@44a90000 <-> /fpga-axi@0/axi-ad9371-tx-hpc@44a04000
    jesd204: created con: id=7, topo=0, link=1, /fpga-axi@0/axi-jesd204-rx@44aa0000 <-> /axi/spi@e0006000/ad9371-phy@1
    jesd204: created con: id=8, topo=0, link=2, /fpga-axi@0/axi-jesd204-rx@44ab0000 <-> /axi/spi@e0006000/ad9371-phy@1
    jesd204: created con: id=9, topo=0, link=0, /fpga-axi@0/axi-ad9371-tx-hpc@44a04000 <-> /axi/spi@e0006000/ad9371-phy@1
    jesd204: /axi/spi@e0006000/ad9371-phy@1: JESD204[0:0] transition uninitialized -> initialized
    jesd204: /axi/spi@e0006000/ad9371-phy@1: JESD204[0:1] transition uninitialized -> initialized
    jesd204: /axi/spi@e0006000/ad9371-phy@1: JESD204[0:2] transition uninitialized -> initialized
    jesd204: found 9 devices and 1 topologies
    FPGA manager framework
    Advanced Linux Sound Architecture Driver Initialized.
    clocksource: Switched to clocksource arm_global_timer
    NET: Registered PF_INET protocol family
    IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
    tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
    TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
    TCP: Hash tables configured (established 8192 bind 8192)
    UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    NET: Registered PF_UNIX/PF_LOCAL protocol family
    RPC: Registered named UNIX socket transport module.
    RPC: Registered udp transport module.
    RPC: Registered tcp transport module.
    RPC: Registered tcp NFSv4.1 backchannel transport module.
    armv7-pmu f8891000.pmu: hw perfevents: no interrupt-affinity property, guessing.
    hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
    workingset: timestamp_bits=30 max_order=18 bucket_order=0
    NFS: Registering the id_resolver key type
    Key type id_resolver registered
    Key type id_legacy registered
    nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    fuse: init (API version 7.34)
    bounce: pool size: 64 pages
    io scheduler mq-deadline registered
    io scheduler kyber registered
    zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
    dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
    dma-pl330 f8003000.dmac: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
    brd: module loaded
    loop: module loaded
    Registered mathworks_ip class
    SPI driver spidev has no spi_device_id for adi,swspi
    spi-nor spi1.0: found s25fl128s1, expected n25q128a11
    random: fast init done
    random: crng init done
    spi-nor spi1.0: s25fl128s1 (32768 Kbytes)
    5 fixed-partitions partitions found on MTD device spi1.0
    Creating 5 MTD partitions on "spi1.0":
    0x000000000000-0x000000500000 : "boot"
    0x000000500000-0x000000520000 : "bootenv"
    0x000000520000-0x000000540000 : "config"
    0x000000540000-0x000000fc0000 : "image"
    0x000000fc0000-0x000002000000 : "spare"
    MACsec IEEE 802.1AE
    tun: Universal TUN/TAP device driver, 1.6
    macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 35 (00:0a:35:00:01:22)
    usbcore: registered new interface driver asix
    usbcore: registered new interface driver ax88179_178a
    usbcore: registered new interface driver cdc_ether
    usbcore: registered new interface driver net1080
    usbcore: registered new interface driver cdc_subset
    usbcore: registered new interface driver zaurus
    usbcore: registered new interface driver cdc_ncm
    ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    usbcore: registered new interface driver uas
    usbcore: registered new interface driver usb-storage
    usbcore: registered new interface driver usbserial_generic
    usbserial: USB Serial support registered for generic
    usbcore: registered new interface driver ftdi_sio
    usbserial: USB Serial support registered for FTDI USB Serial Device
    usbcore: registered new interface driver upd78f0730
    usbserial: USB Serial support registered for upd78f0730
    ULPI transceiver vendor/product ID 0x0424/0x0007
    Found SMSC USB3320 ULPI transceiver.
    ULPI integrity check: passed.
    ci_hdrc ci_hdrc.0: EHCI Host Controller
    ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
    ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
    usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
    usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    usb usb1: Product: EHCI Host Controller
    usb usb1: Manufacturer: Linux 5.15.36-182052-g805c422ae939 ehci_hcd
    usb usb1: SerialNumber: ci_hdrc.0
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 1 port detected
    SPI driver ads7846 has no spi_device_id for ti,tsc2046
    SPI driver ads7846 has no spi_device_id for ti,ads7843
    SPI driver ads7846 has no spi_device_id for ti,ads7845
    SPI driver ads7846 has no spi_device_id for ti,ads7873
    i2c_dev: i2c /dev entries driver
    si570 1-005d: registered, current frequency 156250000 Hz
    i2c i2c-0: Added multiplexed i2c bus 1
    i2c 2-0039: Fixing up cyclic dependency with 70e00000.axi_hdmi
    adv7511 2-0039: supply avdd not found, using dummy regulator
    adv7511 2-0039: supply dvdd not found, using dummy regulator
    adv7511 2-0039: supply pvdd not found, using dummy regulator
    adv7511 2-0039: supply bgvdd not found, using dummy regulator
    adv7511 2-0039: supply dvdd-3v not found, using dummy regulator
    i2c i2c-0: Added multiplexed i2c bus 2
    at24 3-0054: supply vcc not found, using dummy regulator
    at24 3-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
    i2c i2c-0: Added multiplexed i2c bus 3
    pca953x 4-0021: supply vcc not found, using dummy regulator
    pca953x 4-0021: using no AI
    i2c i2c-0: Added multiplexed i2c bus 4
    rtc-pcf8563 5-0051: registered as rtc0
    rtc-pcf8563 5-0051: setting system clock to 2025-11-01T10:18:06 UTC (1761992286)
    i2c i2c-0: Added multiplexed i2c bus 5
    at24 6-0050: supply vcc not found, using dummy regulator
    at24 6-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
    i2c i2c-0: Added multiplexed i2c bus 6
    i2c i2c-0: Added multiplexed i2c bus 7
    i2c i2c-0: Added multiplexed i2c bus 8
    pca954x 0-0074: registered 8 multiplexed busses for I2C switch pca9548
    usbcore: registered new interface driver uvcvideo
    gspca_main: v2.14.0 registered
    cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer with timeout 10s
    Xilinx Zynq CpuIdle Driver started
    failed to register cpuidle driver
    sdhci: Secure Digital Host Controller Interface driver
    sdhci: Copyright(c) Pierre Ossman
    sdhci-pltfm: SDHCI platform and OF driver helper
    ledtrig-cpu: registered to indicate activity on CPUs
    hid: raw HID events driver (C) Jiri Kosina
    usbcore: registered new interface driver usbhid
    usbhid: USB HID core driver
    SPI driver fb_seps525 has no spi_device_id for syncoam,seps525
    mmc0: SDHCI controller on e0100000.mmc [e0100000.mmc] using ADMA
    SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7988-5
    SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7988-1
    SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7984
    SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7983
    SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7982
    SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7980
    SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7949
    SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7946
    SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7942
    SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7699
    SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7693
    SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7691
    SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7690
    SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7689
    SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7688
    SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7687
    SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7686
    SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7685
    SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7682
    SPI driver ad7124 has no spi_device_id for adi,ad7124-4
    SPI driver ad7124 has no spi_device_id for adi,ad7124-8
    SPI driver ad7192 has no spi_device_id for adi,ad7190
    SPI driver ad7192 has no spi_device_id for adi,ad7193
    SPI driver ad7192 has no spi_device_id for adi,ad7195
    SPI driver ad9467 has no spi_device_id for adi,ad9643
    SPI driver ad9467 has no spi_device_id for adi,ad9250
    SPI driver ad9467 has no spi_device_id for adi,ad9250_2
    SPI driver ad9467 has no spi_device_id for adi,ad9265
    SPI driver ad9467 has no spi_device_id for adi,ad9683
    mmc0: new high speed SDHC card at address aaaa
    SPI driver ad9467 has no spi_device_id for adi,ad9434
    mmcblk0: mmc0:aaaa SD32G 29.7 GiB
    SPI driver ad9467 has no spi_device_id for adi,ad9625
    SPI driver ad9467 has no spi_device_id for adi,ad9652
    SPI driver ad9467 has no spi_device_id for adi,ad9649
     mmcblk0: p1 p2 p3
    SPI driver adar3000 has no spi_device_id for adi,adar3001
    SPI driver adar3000 has no spi_device_id for adi,adar3002
    ad9528 spi0.0: supply vcc not found, using dummy regulator
    jesd204: /axi/spi@e0006000/ad9528-1@0,jesd204:0,parent=spi0.0: Using as SYSREF provider
    SPI driver ad9783 has no spi_device_id for adi,ad9780
    SPI driver ad9783 has no spi_device_id for adi,ad9781
    SPI driver adis16475 has no spi_device_id for adi,adis16470
    SPI driver adis16475 has no spi_device_id for adi,adis16475-1
    SPI driver adis16475 has no spi_device_id for adi,adis16475-2
    SPI driver adis16475 has no spi_device_id for adi,adis16475-3
    SPI driver adis16475 has no spi_device_id for adi,adis16477-1
    SPI driver adis16475 has no spi_device_id for adi,adis16477-2
    SPI driver adis16475 has no spi_device_id for adi,adis16477-3
    SPI driver adis16475 has no spi_device_id for adi,adis16465-1
    SPI driver adis16475 has no spi_device_id for adi,adis16465-2
    SPI driver adis16475 has no spi_device_id for adi,adis16465-3
    SPI driver adis16475 has no spi_device_id for adi,adis16467-1
    SPI driver adis16475 has no spi_device_id for adi,adis16467-2
    SPI driver adis16475 has no spi_device_id for adi,adis16467-3
    SPI driver adis16475 has no spi_device_id for adi,adis16500
    SPI driver adis16475 has no spi_device_id for adi,adis16505-1
    SPI driver adis16475 has no spi_device_id for adi,adis16505-2
    SPI driver adis16475 has no spi_device_id for adi,adis16505-3
    SPI driver adis16475 has no spi_device_id for adi,adis16507-1
    SPI driver adis16475 has no spi_device_id for adi,adis16507-2
    SPI driver adis16475 has no spi_device_id for adi,adis16507-3
    axi_adxcvr 44a60000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.05.a) using CPLL on GTX2 at 0x44A60000. Number of lanes: 2.
    axi_adxcvr 44a50000.axi-adxcvr-rx-os: AXI-ADXCVR-RX (17.05.a) using CPLL on GTX2 at 0x44A50000. Number of lanes: 2.
    axi_adxcvr 44a80000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.05.a) using QPLL on GTX2 at 0x44A80000. Number of lanes: 4.
    axi_sysid 45000000.axi-sysid-0: AXI System ID core version (1.01.a) found
    axi_sysid 45000000.axi-sysid-0: [vivado] on [prj] git branch <(HEAD> git <b434568693f2562cd5439dcdd047c21b336c06bb> dirty [2025-10-31 15:36:42] UTC
    fpga_manager fpga0: Xilinx Zynq FPGA Manager registered
    usbcore: registered new interface driver snd-usb-audio
    NET: Registered PF_INET6 protocol family
    Segment Routing with IPv6
    In-situ OAM (IOAM) with IPv6
    sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    NET: Registered PF_PACKET protocol family
    NET: Registered PF_IEEE802154 protocol family
    Key type dns_resolver registered
    zynq_pm_remap_ocm: OCM pool is not available
    zynq_pm_suspend_init: Unable to map OCM.
    Registering SWP/SWPB emulation handler
    of-fpga-region fpga-full: FPGA Region probed
    [drm] Initialized axi_hdmi_drm 1.0.0 20120930 for 70e00000.axi_hdmi on minor 0
    axi-hdmi 70e00000.axi_hdmi: [drm] Cannot find any crtc or sizes
    axi-jesd204-rx 44aa0000.axi-jesd204-rx: AXI-JESD204-RX (1.07.a) at 0x44AA0000. Encoder 8b10b, width 4/4, lanes 2, jesd204-fsm.
    axi-jesd204-rx 44ab0000.axi-jesd204-rx: AXI-JESD204-RX (1.07.a) at 0x44AB0000. Encoder 8b10b, width 4/4, lanes 2, jesd204-fsm.
    axi-jesd204-tx 44a90000.axi-jesd204-tx: AXI-JESD204-TX (1.06.a) at 0x44A90000. Encoder 8b10b, width 4/4, lanes 4, jesd204-fsm.
    debugfs: File 'Capture' in directory 'dapm' already present!
    ad9371 spi0.1: ad9371_probe : enter
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:0] transition initialized -> probed
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:1] transition initialized -> probed
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:2] transition initialized -> probed
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:0] transition probed -> idle
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:1] transition probed -> idle
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:2] transition probed -> idle
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:0] transition idle -> device_init
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:1] transition idle -> device_init
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:2] transition idle -> device_init
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:0] transition device_init -> link_init
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:1] transition device_init -> link_init
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:2] transition device_init -> link_init
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:0] transition link_init -> link_supported
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:1] transition link_init -> link_supported
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:2] transition link_init -> link_supported
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:0] transition link_supported -> link_pre_setup
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:1] transition link_supported -> link_pre_setup
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:2] transition link_supported -> link_pre_setup
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:0] transition link_pre_setup -> clk_sync_stage1
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:1] transition link_pre_setup -> clk_sync_stage1
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:2] transition link_pre_setup -> clk_sync_stage1
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:0] transition clk_sync_stage1 -> clk_sync_stage2
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:1] transition clk_sync_stage1 -> clk_sync_stage2
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:2] transition clk_sync_stage1 -> clk_sync_stage2
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:0] transition clk_sync_stage2 -> clk_sync_stage3
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:1] transition clk_sync_stage2 -> clk_sync_stage3
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:2] transition clk_sync_stage2 -> clk_sync_stage3
    axi_adxcvr 44a80000.axi-adxcvr-tx: QPLL TX  Error: 0
    axi-jesd204-tx 44a90000.axi-jesd204-tx: axi_jesd204_tx_jesd204_link_setup: Link0 enable lane clock failed (-5)
    jesd204: /fpga-axi@0/axi-jesd204-tx@44a90000,jesd204:4,parent=44a90000.axi-jesd204-tx: JESD204[0:0] In link_setup got error from cb: -5
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: Rolling back from 'clk_sync_stage3', got error -5
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:2] transition clk_sync_stage3 -> link_setup
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:1] transition clk_sync_stage3 -> link_setup
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:0] transition clk_sync_stage3 -> link_setup
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:2] transition link_setup -> clk_sync_stage3
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:1] transition link_setup -> clk_sync_stage3
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:0] transition link_setup -> clk_sync_stage3
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:2] transition clk_sync_stage3 -> clk_sync_stage2
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:1] transition clk_sync_stage3 -> clk_sync_stage2
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:0] transition clk_sync_stage3 -> clk_sync_stage2
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:2] transition clk_sync_stage2 -> clk_sync_stage1
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:1] transition clk_sync_stage2 -> clk_sync_stage1
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:0] transition clk_sync_stage2 -> clk_sync_stage1
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:2] transition clk_sync_stage1 -> link_pre_setup
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:1] transition clk_sync_stage1 -> link_pre_setup
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:0] transition clk_sync_stage1 -> link_pre_setup
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:2] transition link_pre_setup -> link_supported
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:1] transition link_pre_setup -> link_supported
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:0] transition link_pre_setup -> link_supported
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:2] transition link_supported -> link_init
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:1] transition link_supported -> link_init
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:0] transition link_supported -> link_init
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:2] transition link_init -> device_init
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:1] transition link_init -> device_init
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:0] transition link_init -> device_init
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:2] transition device_init -> idle
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:1] transition device_init -> idle
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:0] transition device_init -> idle
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:0] transition idle -> idle
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:1] transition idle -> idle
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: JESD204[0:2] transition idle -> idle
    jesd204: /axi/spi@e0006000/ad9371-phy@1,jesd204:1,parent=spi0.1: FSM completed with error -5
    cf_axi_dds 44a04000.axi-ad9371-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x44A04000 mapped to 0xf824beed, probed DDS AD9371
    cf_axi_adc 44a00000.axi-ad9371-rx-hpc: ADI AIM (10.03.�) at 0x44A00000 mapped to 0xe714dfa4 probed ADC AD9371 as MASTER
    input: gpio_keys as /devices/soc0/gpio_keys/input/input0
    of_cfs_init
    of_cfs_init: OK
    clk: Not disabling unused clocks
    ALSA device list:
      #0: HDMI monitor
    EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: disabled.
    VFS: Mounted root (ext4 filesystem) on device 179:2.
    devtmpfs: mounted
    Freeing unused kernel image (initmem) memory: 1024K
    Run /sbin/init as init process
    systemd[1]: systemd 247.3-7+rpi1+deb11u2 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
    systemd[1]: Detected architecture arm.
    Welcome to Kuiper GNU/Linux 11.2 (bullseye)!
    systemd[1]: Set hostname to <analog>.
    systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
    systemd[1]: Queued start job for default target Graphical Interface.
    systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    systemd[1]: Created slice system-modprobe.slice.
    [  OK  ] Created slice system-modprobe.slice.
    systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    systemd[1]: Created slice system-systemd\x2dfsck.slice.
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
    systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    systemd[1]: Listening on Syslog Socket.
    [  OK  ] Listening on Syslog Socket.
    systemd[1]: Listening on fsck to fsckd communication Socket.
    [  OK  ] Listening on fsck to fsckd communication Socket.
    systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    systemd[1]: Condition check resulted in Huge Pages File System being skipped.
    systemd[1]: Condition check resulted in POSIX Message Queue File System being skipped.
    systemd[1]: Mounting RPC Pipe File System...
    systemd[1]: Mounting Kernel Debug File System...
    systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
    systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
    systemd[1]: Starting Restore / save the current clock...
    systemd[1]: Starting Set the console keyboard layout...
    systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
    systemd[1]: Starting Load Kernel Module configfs...
    systemd[1]: Starting Load Kernel Module drm...
    systemd[1]: Starting Load Kernel Module fuse...
    systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
    systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    systemd[1]: Starting Journal Service...
    systemd[1]: Starting Load Kernel Modules...
    systemd[1]: Starting Remount Root and Kernel File Systems...
    systemd[1]: Starting Coldplug All udev Devices...
    systemd[1]: Mounted RPC Pipe File System.
    [  OK  ] Mounted RPC Pipe File System.
    systemd[1]: Mounted Kernel Debug File System.
    [  OK  ] Mounted Kernel Debug File System.
    systemd[1]: Finished Restore / save the current clock.
    [  OK  ] Finished Restore / save the current clock.
    systemd[1]: modprobe@configfs.service: Succeeded.
    systemd[1]: Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module configfs.
    systemd[1]: modprobe@drm.service: Succeeded.
    systemd[1]: Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module drm.
    systemd[1]: modprobe@fuse.service: Succeeded.
    systemd[1]: Finished Load Kernel Module fuse.
    [  OK  ] Finished Load Kernel Module fuse.
    systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
    systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
    systemd[1]: Failed to start Load Kernel Modules.
    [FAILED] Failed to start Load Kernel Modules.
    See 'systemctl status systemd-modules-load.service' for details.
    systemd[1]: Mounting FUSE Control File System...
    systemd[1]: Mounting Kernel Configuration File System...
    systemd[1]: Starting Apply Kernel Variables...
    systemd[1]: Finished Set the console keyboard layout.
    [  OK  ] Finished Set the console keyboard layout.
    systemd[1]: Mounted FUSE Control File System.
    [  OK  ] Mounted FUSE Control File System.
    EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: disabled.
    [  OK  ] Finished Remount Root and Kernel File Systems.
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Finished Apply Kernel Variables.
             Starting Load/Save Random Seed...
             Starting Create System Users...
    [  OK  ] Started Journal Service.
             Starting Flush Journal to Persistent Storage...
    [  OK  ] Finished Load/Save Random Seed.
    [  OK  ] Finished Create System Users.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Finished Coldplug All udev Devices.
             Starting Helper to synchronize boot up for ifupdown...
             Starting Wait for udev To …plete Device Initialization...
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Finished Helper to synchronize boot up for ifupdown.
    [  OK  ] Reached target Local File Systems (Pre).
             Starting Rule-based Manage…for Device Events and Files...
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Started Rule-based Manager for Device Events and Files.
             Starting Show Plymouth Boot Screen...
    [  OK  ] Started Show Plymouth Boot Screen.
    [  OK  ] Started Forward Password R…s to Plymouth Directory Watch.
    [  OK  ] Reached target Local Encrypted Volumes.
    [  OK  ] Found device /dev/ttyPS0.
    [  OK  ] Found device /dev/disk/by-partuuid/bbd63575-01.
             Starting File System Check…isk/by-partuuid/bbd63575-01...
    [  OK  ] Started File System Check Daemon to report status.
    [  OK  ] Finished Wait for udev To Complete Device Initialization.
    [  OK  ] Finished File System Check…/disk/by-partuuid/bbd63575-01.
             Mounting /boot...
    [  OK  ] Mounted /boot.
    [  OK  ] Reached target Local File Systems.
             Starting Set console font and keymap...
             Starting Raise network interfaces...
             Starting Preprocess NFS configuration...
             Starting Tell Plymouth To Write Out Runtime Data...
             Starting Create Volatile Files and Directories...
    [  OK  ] Finished Preprocess NFS configuration.
    [  OK  ] Finished Set console font and keymap.
    [  OK  ] Finished Tell Plymouth To Write Out Runtime Data.
    [  OK  ] Reached target NFS client services.
    [  OK  ] Reached target Remote File Systems (Pre).
    [  OK  ] Reached target Remote File Systems.
    [  OK  ] Finished Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Finished Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [  OK  ] Finished Raise network interfaces.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started CUPS Scheduler.
    [  OK  ] Started Daily apt download activities.
    [  OK  ] Started Daily apt upgrade and clean activities.
    [  OK  ] Started Periodic ext4 Onli…ata Check for All Filesystems.
    [  OK  ] Started Discard unused blocks once a week.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily man-db regeneration.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Paths.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on CUPS Scheduler.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [  OK  ] Listening on Erlang Port Mapper Daemon Activation Socket.
    [  OK  ] Listening on GPS (Global P…ioning System) Daemon Sockets.
    [  OK  ] Listening on triggerhappy.socket.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
             Starting Analog Devices power up/down sequence...
             Starting Save/Restore Sound Card State...
             Starting Avahi mDNS/DNS-SD Stack...
    [  OK  ] Started Regular background program processing daemon.
    [  OK  ] Started D-Bus System Message Bus.
             Starting dphys-swapfile - …unt, and delete a swap file...
             Starting Remove Stale Onli…t4 Metadata Check Snapshots...
             Starting Creating IIOD Context Attributes......
             Starting Authorization Manager...
             Starting DHCP Client Daemon...
             Starting LSB: Switch to on…nless shift key is pressed)...
             Starting LSB: rng-tools (Debian variant)...
             Starting System Logging Service...
             Starting User Login Management...
             Starting triggerhappy global hotkey daemon...
             Starting Disk Manager...
             Starting WPA supplicant...
    [  OK  ] Finished Save/Restore Sound Card State.
    [  OK  ] Reached target Sound Card.
             Starting Rotate log files...
             Starting Daily man-db regeneration...
    [  OK  ] Started triggerhappy global hotkey daemon.
    [  OK  ] Started System Logging Service.
    [  OK  ] Started DHCP Client Daemon.
    [  OK  ] Finished dphys-swapfile - …mount, and delete a swap file.
    [  OK  ] Started LSB: rng-tools (Debian variant).
    [  OK  ] Started Authorization Manager.
    [  OK  ] Started WPA supplicant.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started User Login Management.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Network is Online.
             Starting Modem Manager...
             Starting CUPS Scheduler...
    [  OK  ] Started Erlang Port Mapper Daemon.
             Starting HTTP based time synchronization tool...
             Starting Internet superserver...
             Starting /etc/rc.local Compatibility...
             Starting OpenBSD Secure Shell server...
             Starting Permit User Sessions...
    [  OK  ] Started Unattended Upgrades Shutdown.
    [  OK  ] Started Internet superserver.
    [  OK  ] Finished Remove Stale Onli…ext4 Metadata Check Snapshots.
    [  OK  ] Started /etc/rc.local Compatibility.
    [  OK  ] Started Make remote CUPS printers available locally.
    [  OK  ] Finished Permit User Sessions.
             Starting Light Display Manager...
             Starting Hold until boot process finishes up...
    [  OK  ] Started LSB: Switch to ond…(unless shift key is pressed).
    [  OK  ] Started HTTP based time synchronization tool.
    [  OK  ] Started Modem Manager.
    [  OK  ] Finished Analog Devices power up/down sequence.
    [FAILED] Failed to start VNC Server for X11.
    Raspbian GNU/Linux 11 analog ttyPS0
    analog login: root (automatic login)
    Linux analog 5.15.36-182052-g805c422ae939 #1545 SMP PREEMPT Tue Jun 18 10:34:01 EEST 2024 armv7l
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    Last login: Fri Oct 31 17:07:52 GMT 2025 on ttyPS0
    [?2004hroot@analog:~#
  • Hello!
    Since it has been a while since the last activity on this thread, do you have any updates?
    Regards, Elena
