Cannot open ad936x tab or advance tab with IIO Scope and Pluto on Linux
The user encountered issues with the AD936x tab not showing up in IIO Oscilloscope on PopOS and Ubuntu. Compiling IIO Scope was necessary to get the AD936x tab to appear, but on PopOS, the compiled version crashes upon reopening. The user found that running the app-image release from GitHub works reliably without crashes on both OSes. The solution involves ensuring libad9361-iio and libosc.so are correctly installed and accessible.
Product Number: Pluto
Hello, I am trying to run IIO Oscilloscope on Linux but I am having difficulties gaining control of basic functionality in Linux, namely the ad936x tab is now showing up. My OS information below:
Linux pop-os 6.12.10-76061203-generic #202412060638~1751390742~22.04~79b9668 SMP PREEMPT_DYNAMIC Tue J x86_64 x86_64 x86_64 GNU/Linux
Only the "debug", "DMM" and "Data Manager" tab is available but not the usual ad9361 tab.
I am using the latest release here (v0.18-main) found in the osc-linux zip file
https://github.com/analogdevicesinc/iio-oscilloscope/releases/download/v0.18-main/osc-linux-x86_64-710df32.zip
Is a compilation still necessary in Linux for this release? If so, I even tried re-compiling everything following these instructions:
https://wiki.analog.com/resources/tools-software/linux-software/iio_oscilloscope#linux
https://wiki.analog.com/resources/tools-software/linux-software/libiio#how_to_build_it
The compilation seems to succeed and places osc in /usr/bin/osc. I run osc from the /build directory with the library path (LD_LIBRARY_PATH) included:
Log of the executable below:
/projects/oscope/build/iio-oscilloscope/build$ ./osc
(osc:3325604): Gtk-WARNING **: 15:49:16.206: Could not load image 'osc128.png': Failed to open file “./glade/osc128.png”: No such file or directory
(osc:3325604): Gtk-WARNING **: 15:49:16.229: Could not load image 'IIOlogo.png': Failed to open file “./glade/IIOlogo.png”: No such file or directory
(osc:3325604): Gtk-WARNING **: 15:49:16.229: Could not load image 'ADIlogo.png': Failed to open file “./glade/ADIlogo.png”: No such file or directory
Found plugin: Debug
Found plugin: FMCOMMS11
Found plugin: AD5628-1
Found plugin: Partial Reconfiguration
Found plugin: AD9371 Advanced
Found plugin: FMCADC3
Found plugin: AD6676
Found plugin: DAC Data Manager
Found plugin: LIDAR
Found plugin: CN0508
Found plugin: CN0357
Found plugin: ad9739a
Found plugin: FMComms6
Found plugin: FMComms5
Found plugin: XMW
Found plugin: DMM
Found plugin: CN0540
Could not find expected iio devices
Found plugin: ADRV9009
Found plugin: Motor Control
Found plugin: DAQ1/2/3
Failed to load plugin "adrv9002.so"Found plugin: SCPI
Closing plugin: Debug
Closing plugin: DMM
Found plugin: Debug
Found plugin: LIDAR
Found plugin: XMW
Found plugin: DMM
Loaded plugin: DAC Data Manager
(osc:3325604): Gtk-WARNING **: 15:49:16.443: Could not load image 'ADIlogo.png': Failed to open file “./glade/ADIlogo.png”: No such file or directory
(osc:3325604): Gtk-WARNING **: 15:49:16.460: Content added to the action area of a dialog using header bars
setting all off
Despite this, I still cannot get anything to appear for the ad936x tab. Here is the output of iio_info
iio_info
iio_info version: 0.25 (git tag:v0.25)
Libiio version: 0.25 (git tag: v0.25) backends: local xml ip usb
IIO context created with local backend.
Backend version: 0.25 (git tag: v0.25)
Backend description string: Linux pop-os 6.12.10-76061203-generic #202412060638~1751390742~22.04~79b9668 SMP PREEMPT_DYNAMIC Tue J x86_64
IIO context has 2 attributes:
	local,kernel: 6.12.10-76061203-generic
	uri: local:
IIO context has 14 devices:
	hwmon0: AC
		0 channels found:
		No trigger on this device
	hwmon1: acpi_fan
		1 channels found:
			fan1:  (input)
			1 channel-specific attributes found:
				attr  0: input value: 2369
	hwmon10: coretemp
		25 channels found:
			temp46:  (input)
			5 channel-specific attributes found:
				attr  0: crit value: 105000
				attr  1: crit_alarm value: 0
				attr  2: input value: 54000
				attr  3: label value: Core 44
				attr  4: max value: 105000
			temp42:  (input)
				attr  2: input value: 56000
				attr  3: label value: Core 40
			temp26:  (input)
				attr  3: label value: Core 24
			temp17:  (input)
				attr  3: label value: Core 15
			temp10:  (input)
				attr  3: label value: Core 8
			temp35:  (input)
				attr  3: label value: Core 33
			temp37:  (input)
				attr  3: label value: Core 35
			temp30:  (input)
				attr  3: label value: Core 28
			temp34:  (input)
				attr  2: input value: 52000
				attr  3: label value: Core 32
			temp14:  (input)
				attr  3: label value: Core 12
			temp12:  (input)
				attr  3: label value: Core 10
			temp15:  (input)
				attr  3: label value: Core 13
			temp36:  (input)
				attr  3: label value: Core 34
			temp40:  (input)
				attr  3: label value: Core 38
			temp6:  (input)
			temp22:  (input)
				attr  3: label value: Core 20
			temp16:  (input)
				attr  3: label value: Core 14
			temp2:  (input)
				attr  3: label value: Core 0
			temp13:  (input)
				attr  3: label value: Core 11
			temp18:  (input)
				attr  3: label value: Core 16
			temp11:  (input)
				attr  3: label value: Core 9
			temp38:  (input)
				attr  3: label value: Core 36
			temp39:  (input)
				attr  3: label value: Core 37
			temp1:  (input)
				attr  3: label value: Package id 0
			temp41:  (input)
				attr  3: label value: Core 39
	hwmon11: iwlwifi_1
		1 channels found:
			temp1:  (input)
				attr  0: input value: 47000
	hwmon2: acpi_fan
		1 channels found:
			fan1:  (input)
				attr  0: input value: 0
	hwmon3: acpitz
		1 channels found:
			temp1:  (input)
				attr  0: input value: 56000
	hwmon4: BAT0
		2 channels found:
			in0:  (input)
				attr  0: input value: 17671
			curr1:  (input)
	hwmon5: nvme
		3 channels found:
			temp2:  (input)
			4 channel-specific attributes found:
				attr  0: input value: 35850
				attr  1: label value: Sensor 1
				attr  2: max value: 65261850
				attr  3: min value: -273150
			temp3:  (input)
				attr  0: input value: 36850
				attr  1: label value: Sensor 2
			temp1:  (input)
			6 channel-specific attributes found:
				attr  0: alarm value: 0
				attr  1: crit value: 84850
				attr  2: input value: 35850
				attr  3: label value: Composite
				attr  4: max value: 81850
				attr  5: min value: -273150
	hwmon6: nvme
		2 channels found:
			temp2:  (input)
				attr  0: input value: 32850
			temp1:  (input)
				attr  2: input value: 32850
				attr  4: max value: 82850
				attr  5: min value: -150
	hwmon7: system76
		6 channels found:
			fan1:  (input)
			2 channel-specific attributes found:
				attr  1: label value: CPU fan
			temp1:  (input)
				attr  1: label value: CPU temperature
			pwm1:  (input)
				attr  0: enable value: 2
				attr  1: pwm1 value: 0
			pwm2:  (input)
				attr  1: pwm2 value: 0
			fan2:  (input)
				attr  1: label value: GPU fan
			temp2:  (input)
				attr  0: input value: 48000
				attr  1: label value: GPU temperature
	hwmon8: hidpp_battery_0
		0 channels found:
	hwmon9: spd5118
		1 channels found:
			temp1:  (input)
			10 channel-specific attributes found:
				attr  0: crit value: 85000
				attr  2: enable value: 1
				attr  3: input value: 49000
				attr  4: lcrit value: 0
				attr  5: lcrit_alarm value: 0
				attr  6: max value: 55000
				attr  7: max_alarm ERROR: No such device or address (6)
				attr  8: min value: 0
				attr  9: min_alarm value: 0
	iio:device0: prox (buffer capable)
		1 channels found:
			proximity:  (input, index: 0, format: le:s8/32>>0)
				attr  0: hysteresis ERROR: Invalid argument (22)
				attr  1: offset value: 0
				attr  2: raw value: 1
				attr  3: sampling_frequency value: 10.000000
				attr  4: scale value:
		1 device-specific attributes found:
				attr  0: waiting_for_supplier value: 0
		2 buffer-specific attributes found:
				attr  0: data_available value: 0
				attr  1: direction value: in
		Current trigger: trigger0(prox-dev0)
	trigger0: prox-dev0
		0 channels found:
What am I doing wrong? Advice much appreciated. Thanks
  • Hello,
    Did you install the Pluto drivers?
    Stanca
  • Connected context looks like the host PC and not the target system with a AD936X. Point it to Pluto's uri.
    -Travis
  • I also tried a manual IP for an ADRV9361 device and it did not work either.
    I ended up doing a rebuild of everything but also included this optional step here:
    After rebuilding IIO-Scope it gets placed in /usr/local/bin/osc and it seems to work. I can also run the app-image off of the github release too (osc-linux-x86_64-710df32.zip)
    Another problem I found was that on different machine re-attempting the re-build steps, osc gets installed but it is missing a library location
    ldd /usr/local/bin/osc
    linux-vdso.so.1 (0x000075ec570a1000)
    libgtk-3.so.0 => /lib/x86_64-linux-gnu/libgtk-3.so.0 (0x000075ec56800000)
    libgdk_pixbuf-2.0.so.0 => /lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so.0 (0x000075ec5704b000)
    libgobject-2.0.so.0 => /lib/x86_64-linux-gnu/libgobject-2.0.so.0 (0x000075ec567a0000)
    libglib-2.0.so.0 => /lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x000075ec56666000)
    libiio.so.0 => /lib/x86_64-linux-gnu/libiio.so.0 (0x000075ec57029000)
    libosc.so.0 => not found
    when I add libosc.so on the path:
    export LD_LIBRARY_PATH="/usr/local/lib:$LD_LIBRARY_PATH"
    I can run osc (which runs from /usr/local/bin) and see devices and connect. However, running osc a second time results in a crash:
    IIO-Oscilloscope Crash Info
    PID: 3580424
    Signal No: 11
    Signal String: Segmentation fault
    Error No: -12102
    Error String: Unknown error -12102
    Time Stamp: Tue Sep 9 10:48:21 2025
    IIO-Oscilloscope Backtrace
    osc(obtainBacktrace+0x61)[0x5d55e7430f11]
    /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7e9698042520]
    /lib/x86_64-linux-gnu/libc.so.6(+0x198962)[0x7e9698198962]
    /lib/x86_64-linux-gnu/libiio.so.0(iio_channel_find_attr+0x57)[0x7e9698e3e197]
    /lib/x86_64-linux-gnu/libiio.so.0(iio_channel_attr_write_raw+0x17)[0x7e9698e3e2a7]
    /lib/x86_64-linux-gnu/libiio.so.0(iio_channel_attr_write_all+0xc1)[0x7e9698e3f151]
    /usr/local/lib/libosc.so.0(update_from_ini+0xfb)[0x7e9698449a5b]
    /usr/local/lib/osc//fmcomms2_adv.so(+0x6552)[0x7e968379a552]
    /usr/local/lib/libosc.so.0(+0x1affb)[0x7e969842affb]
    /usr/local/lib/libosc.so.0(load_default_profile+0x93)[0x7e969842b243]
    osc(main+0x137)[0x5d55e7430d07]
    /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7e9698029d90]
    /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7e9698029e40]
    osc(_start+0x25)[0x5d55e7430de5]
    Not sure why this is happening on this particular machine despite trying to replicate the same build steps from the other PC.
    In the mean-time, I will be running the app-image release since that seems to work reliably without crashing and is able to discover/connect to all the devices without issues after compiling IIO-Scope. I don't know compiling IIO Scope was necessary for the latest app-image to work (the release notes seem to suggest compilation was not necessary for osc-linux-x86_64-710df32.zip)
    Can you expand on what you did?
    What OS are you using?
    -Travis
  • Can you expand on what you did?
    For specifying the IP manually with the ADRV9361 (instead of using the discover/scan feature) I did the following:
    The device is discover-able
    As stated in my previous post, a compilation of IIO Scope was necessary to get access to all the tabs (ie: AD936x and AD936X Advanced). The same missing-tabs problem occurs when connecting to the Pluto. Compiling IIO Scope seems to create all the necessary shared objects (ie: libad9361-iio.so, libosc.so) and adds them to the path.
    I'm trying two different OS/machines and getting different results
    Ubuntu
    Linux 6.5.0-14-generic #14~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Mon Nov 20 18:15:30 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
    I was able to get this to work after compiling IIO Scope. Can run IIO Scope from /usr/bin/osc or from the stand-alone release tag app-image off of github. A compilation was still necessary to get the app-image IIO Scope tabs to all show up.
    PopOS
    Despite compiling IIO Scope with the same steps on Ubuntu, I was only able to get the app-image IIO Scope to work. /usr/bin/osc does not load properly due to missing libraries that do not get added correctly
    osc: error while loading shared libraries: libosc.so.0
    If i add the output of my build to the path such that libosc.so is visible, IIO Scope /usr/bin/osc can only run once and re-opening it causes a crash (see previous post for crash details)
    In the mean-time I will be using the IIO Scope app-image release on PopOS.
  • So yes you need libad9361-iio to use the AD936x tabs.
    In regards with installing from source. The make install command isn't perfect. It really depends on you end target and pathing.
    Where "make install" put libosc.so? is it on your path?
    -Travis
  • It looks to me it gets placed in
    /usr/local/lib
    I did an md5sum comparison and it matches the build output. When adding this to the path it works, running OSC will work.
    export LD_LIBRARY_PATH=/usr/local/lib
    But it will crash when trying to run it again after closing it.
    PID: 650089
    Signal No: 11
    Error No: -14319
    Error String: Unknown error -14319
    Time Stamp: Thu Sep 11 15:13:27 2025
    osc(obtainBacktrace+0x61)[0x5865ebac9f11]
    /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x726fd4e42520]
    /lib/x86_64-linux-gnu/libc.so.6(+0x198962)[0x726fd4f98962]
    /lib/x86_64-linux-gnu/libiio.so.0(iio_channel_find_attr+0x57)[0x726fd5b2a197]
    /lib/x86_64-linux-gnu/libiio.so.0(iio_channel_attr_write_raw+0x17)[0x726fd5b2a2a7]
    /lib/x86_64-linux-gnu/libiio.so.0(iio_channel_attr_write_all+0xc1)[0x726fd5b2b151]
    /usr/local/lib/libosc.so.0(update_from_ini+0xfb)[0x726fd5b03a5b]
    /usr/local/lib/osc//fmcomms2_adv.so(+0x6552)[0x726fcc0ec552]
    /usr/local/lib/libosc.so.0(+0x1affb)[0x726fd5ae4ffb]
    /usr/local/lib/libosc.so.0(load_default_profile+0x93)[0x726fd5ae5243]
    osc(main+0x137)[0x5865ebac9d07]
    /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x726fd4e29d90]
    /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x726fd4e29e40]
    osc(_start+0x25)[0x5865ebac9de5]
    Despite all this, I can just run the image-app from the git release and it works fine. I'm OK marking this as "resolved" despite this strange build hiccup since I have a way around this issue. But any further advice on this would be helpful.
    Thanks
