Error due to Decimation setting in High-Speed Converter Toolbox
Product Number: AD9081
Software Version: 22.2.1
About the Analog Devices, Inc. High-Speed Converter Toolbox.
I'm getting an error when trying to simulate the AD9081 DDC function using this tool.
Reducing ChannelizerPathDecimation from 8 to 4 eliminates the error.
How can I prevent the error from occurring when setting ChannelizerPathDecimation = 8?
■Settings that cause the error
rx = adi.sim.AD9081.Rx;
rx.MainDataPathDecimation = 2;
rx.ChannelizerPathDecimation = 8;
■Settings that do not cause the error
rx.ChannelizerPathDecimation = 4;
Best regards
  • What error are you getting? Your post does not include it.
    -Travis
  • Thank you for your reply.
    The error and simulation settings are as follows:
    ■Error
    The accumulator word length must be 128 bits or shorter.
    error: dsp.FilterCascade/stepImpl (line 433)
    y = step(stage, y);
    error: adi.sim.common.FDDC/stepImpl (line 127)
    u = obj.FilterPath(u);
    error: adi.sim.AD9081.Rx/stepImpl (line 434)
    channelizerPathOut1 = obj.FDDC1(uMux2out(:,1));
    error: AD9081Simtest_20250714>AD9081Simtest (line 121)
    [o1,o2,o3,o4,o5,o6,o7,o8] = rx(data_x_i,data_x_q,data_y_i,data_y_q);
    error: AD9081Simtest_20250714 (line 23)
    [o1,o2,o3,o4,o5,o6,o7,o8] = AD9081Simtest(data_x_i,data_x_q,data_y_i,data_y_q);
    View stack trace:
    • dsp.FilterCascade>FilterCascade.stepImpl (line 433)
    • adi.sim.common.FDDC>FDDC.stepImpl (line 127)
    • adi.sim.AD9081.Rx>Rx.stepImpl (line 434)
    • AD9081Simtest_20250714>AD9081Simtest (line 121)
    • AD9081Simtest_20250714 (line 23)
    ■simulation settings
    function [o1,o2,o3,o4,o5,o6,o7,o8] =AD9081Simtest(data_x_i,data_x_q,data_y_i,data_y_q)
    rx.Crossbar4x4Mux0 = [1,2,3,4];
    rx.ModeSelectMux1 = true;
    rx.SampleRate = 1.6e9;
    rx.Crossbar4x8Mux2 = [1,1,1,1,3,3,3,3];
    rx.CDDCNCOEnable = [false,false,false,false];
    rx.FDDCNCOEnable = [true,true,true,true,true,true,true,true];
    rx.CDDCNCOFrequencies = [100e6, 200e6, 300e6, 400e6];
    rx.FDDCNCOFrequencies = [100e6, 200e6, 300e6, 101e6, 100e6, 200e6, 300e6, 101e6];
    rx.PFIREnable = false;
    rx.delete
    end
  • After adjusting the sampling rate settings, etc., I was able to confirm the DDC function in the AD9081 simulation. However, I encountered the following problems.
    Could you please tell me the cause and solution?
    1. When I checked the AD9081's DDC function using input data normalized to an amplitude of 1, the output data was in the hundreds. I was expecting data normalized to 1 to be output, so could you please tell me the cause?
    2. The initial phase of the NCO in the simulation is not 0.
    How do I set the initial phase of the NCO in the simulation?
    3. If I don't set the initial phase of the NCO in the simulation, what value will the initial phase of the NCO be?
